Connect to your external solutions and transfer data at 10x the speed of USB 2.0. StarTech.com's 6ft USB 3.0 cable (A-B, male-male) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, the 6ft USB 3.0 cable offers a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 6ft USB 3.0 cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
- StarTech.com 6 ft / 2m SuperSpeed USB 3.0 Cable A to B - 1 - USB 3.0 A (Male) to 1 - USB 3.0 B (Male) (USB3SAB6) - USB cable - USB Type A to USB Type B - 1.8 m
- USB cable
- Technology
- Shielded twisted pair (STP)
- 5 Gbps data rate
- Length
- 1.8 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 9 pin USB Type B - male
- USB 3.0
- Blue
- Limited lifetime warranty
- Designed For
- P/N: BNDTBUSB3142, HB20A4AME, HB20A7AME, HBS304A24A, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB312EIC, PEXUSB314A2V, PEXUSB314A2V2, S352BU33HR, SDOCK2ERU33, SDOCK2U33V, SDOCKU33EBV, SDOCKU33EF, ST103008U2C, SV431DD2DU3A, SV431DHD4KU, SV431HDU3A2, TB2USB3GE, USB3SMDOCK4K
- USB cable
- Technology
- American Wire Gauge (AWG)
- 28
- 5 Gbps data rate
- Length
- 1.8 m
- Blue
- Connector
- USB 3.0, RoHS
- Designed For
- P/N: 35BAYUSB3S4, BNDTBUSB3142, ECUSB3S11, ECUSB3S254F, FCREADHCU3, HB20A4AME, HB20A7AME, HBS304A24A, MPEXUSB3S22B, PCIUSB3S22, PCIUSB3S4, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB312EIC, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S11, S3510BMU33, S3510SMU33, S3520BU33ER, S352BU33HR, SATDOCK2REU3, SATDOCKU3S, SDOCK2ERU33, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, ST103008U2C, ST4300MINU3B, ST4300MINU3W, ST4300PBU3, ST4300U3C3, ST4300USB3, ST4300USB3EU, ST4300USB3GB, ST4300USBM, ST7300USB3B, SV431DD2DU3A, SV431DHD4KU, SV431HDU3A2, TB2USB3GE, USB3SDOCKD, USB3SDOCKHD, USB3SDOCKHDV, USB3SEXT5DSK, USB3SMDOCK4K
