StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to A - M/M
Quicklinx: 6LB3WS00 Mfr#: USB3SAA6
Length: 1.8m
£6.21 ex VAT
£7.45 inc VAT
Connect USB 3.0 A devices to a USB hub or to your computer. StarTech.com's 6ft SuperSpeed USB 3.0 cable (A-A) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 A to A Male/Male cable provides connectivity between a PC and hub or other USB A devices, delivering a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 6ft USB 3.0 A to A device cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
StarTech.com 6 ft / 2m SuperSpeed USB 3.0 Cable A to A - USB 3 A (m) to USB 3 A (m) (USB3SAA6) - USB cable - 1.8 m
USB cable
Shielded twisted pair (STP)
5 Gbps data rate
Length
1.8 m
Connector
9 pin USB Type A - male
Connector (Second End)
USB 3.0
Blue
P/N: BNDTBUSB3142, ECUSB3S11, ECUSB3S254F, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB3S3GE, ST103008U2C, ST4300MINU3B, ST4300MINU3W, ST4300PBU3, ST4300U3C3, ST4300USB3EU, ST53004U1C, ST93007U2C, SV231DPU34K, SV431DPU3A2, TB2USB3GE, USB32VGAEH, USB3EXT6INBK
USB cable
American Wire Gauge (AWG)
28
5 Gbps data rate
Length
1.8 m
Blue
Connector
USB 3.0, RoHS
P/N: BNDTBUSB3142, ECUSB3S11, ECUSB3S254F, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB3S11, PEXUSB3S3GE, ST103008U2C, ST4300MINU3B, ST4300MINU3W, ST4300PBU3, ST4300U3C3, ST4300USB3, ST4300USB3EU, ST4300USB3GB, ST53004U1C, ST93007U2C, SV231DPU34K, SV431DPU3A2, TB2USB3GE, USB32VGAEH, USB3EXT6INBK
6LB3 StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.21
6LB3 StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £7.61
6LB3 StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £2.92
6LB3 StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.88
6LB3 StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.16
Length: 1.8m
Price Range Ex VAT: 0 - 50
