Connect USB 3.0 A devices to a USB hub or to your computer. StarTech.com's 6ft SuperSpeed USB 3.0 cable (A-A) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 A to A Male/Male cable provides connectivity between a PC and hub or other USB A devices, delivering a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 6ft USB 3.0 A to A device cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
- StarTech.com 6 ft / 2m SuperSpeed USB 3.0 Cable A to A - USB 3 A (m) to USB 3 A (m) (USB3SAA6) - USB cable - USB Type A to USB Type A - 1.8 m
- USB cable
- Technology
- Shielded twisted pair (STP)
- 5 Gbps data rate
- Length
- 1.8 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- USB 3.0
- Blue
- Limited lifetime warranty
- Designed For
- P/N: BNDTBUSB3142, ECUSB3S11, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S3GE, ST103008U2C, ST4300MINU3B, ST4300MINU3W, ST4300PBU3, ST4300U3C3, ST4300USB3EU, ST53004U1C, ST93007U2C, SV231DPU34K, SV431DPU3A2, TB2USB3GE, USB32VGAEH, USB3EXT6INBK
- USB cable
- Technology
- American Wire Gauge (AWG)
- 28
- 5 Gbps data rate
- Length
- 1.8 m
- Blue
- Connector
- USB 3.0, RoHS
- Designed For
- P/N: BNDTBUSB3142, ECUSB3S11, ECUSB3S254F, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S11, PEXUSB3S3GE, ST103008U2C, ST4300MINU3B, ST4300MINU3W, ST4300PBU3, ST4300U3C3, ST4300USB3, ST4300USB3EU, ST4300USB3GB, ST53004U1C, ST93007U2C, SV231DPU34K, SV431DPU3A2, TB2USB3GE, USB32VGAEH, USB3EXT6INBK
StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £7.60 |
StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.21 |
