The USBUPS06 6-foot Smart UPS Replacement USB cable features 1 USB type "A" (male) connector and 1 10-pin RJ45 male connector, allowing you to communicate from your computer, work station or server to your UPS power supply.
This affordable and cost-effective USB UPS cable can be used as a direct replacement to the AP9827, providing you with the same capabilities at an inexpensive price.
Durable construction
The cable features a robust 28 AWG wire that ensures long-lasting performance and dependable connectivity, making it suitable for frequent use. -
Flexible connectivity
With its 6 ft length, this cable provides ample length for connecting devices comfortably, allowing for organized setups without unnecessary clutter. -
Secure connections
Equipped with male connectors on both ends, this cable ensures a snug fit, minimizing the chances of disconnection during operation.
- StarTech.com 6 ft Smart UPS Replacement USB Cable AP9827 - USB cable - USB (M) to RJ-45 (10 pin) (M) - 6 ft - black - USBUPS06 - USB cable - USB to RJ-45 (10 pin) - 1.8 m
- USB cable
- Length
- 1.8 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- RJ-45 (10 pin) - male
- Black
- Limited lifetime warranty
- USB cable
- American Wire Gauge (AWG)
- 28
- Length
- 1.8 m
- Black
- Connector
