StarTech.com 6 ft Smart UPS Replacement USB Cable AP9827
Quicklinx: 7B86WS00 Mfr#: USBUPS06
Length: 1.8m
£16.24 ex VAT
£19.48 inc VAT
The USBUPS06 6-foot Smart UPS Replacement USB cable features 1 USB type "A" (male) connector and 1 10-pin RJ45 male connector, allowing you to communicate from your computer, work station or server to your UPS power supply.
This affordable and cost-effective USB UPS cable can be used as a direct replacement to the AP9827, providing you with the same capabilities at an inexpensive price.
  • Durable construction
    The cable features a robust 28 AWG wire that ensures long-lasting performance and dependable connectivity, making it suitable for frequent use.
  • Flexible connectivity
    With its 6 ft length, this cable provides ample length for connecting devices comfortably, allowing for organized setups without unnecessary clutter.
  • Secure connections
    Equipped with male connectors on both ends, this cable ensures a snug fit, minimizing the chances of disconnection during operation.
StarTech.com 6 ft Smart UPS Replacement USB Cable AP9827 - USB cable - USB (M) to RJ-45 (10 pin) (M) - 6 ft - black - USBUPS06 - USB cable - USB to RJ-45 (10 pin) - 1.8 m
USB cable
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
RJ-45 (10 pin) - male
USB cable
American Wire Gauge (AWG)
28
Length
1.8 m
Connector
Length: 1.8m
