StarTech.com 6 ft Simple Signaling Serial UPS Cable AP9823
Quicklinx: 7B7JWS00 Mfr#: SIMPLEUPS06
The SIMPLEUPS06 6-foot Simple Signaling Serial UPS cable features 1 DB9 male connector and 1 DB9 female connector, allowing you to communicate from your computer, work station or server to your UPS power supply. This cost-effective Serial UPS cable can be used as a direct replacement to the AP9823.
StarTech.com Simple Signaling Serial UPS Cable AP9823 - serial cable - DB-9 to DB-9 - 1.8 m
Serial cable
Length
1.8 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Grey
Serial cable
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1.8 m
Grey
Connector
RoHS
