StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F
Quicklinx: 6BBRWS00 Mfr#: DB9CONCABL6
Length: 1.8m
Colour: Blue
34 in stock
£19.80 ex VAT
£23.76 inc VAT
Connect your computer's serial port to the RJ45 console port on your Cisco router. The DB9CONCABL6 6ft Cisco Console Management Cable is designed as a replacement cable for use with several Cisco routers, including the 600, 800, 1600 and 1700 series.
StarTech.com's Cisco Console Management cable is Equivalent to Cisco Part No. CAB-CONSOLE-RJ45 and AIR-CONCAB1200 Console Cable for 1130AG, 1200, 1230AG, and 1240 Platforms.
StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F Serial Console Cable (DB9CONCABL6) - serial cable - RJ-45 to DB-9 - 1.8 m
Serial cable
Length
1.8 m
Connector
RJ-45 - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Blue
P/N: EC1S952, EC2S952, IES101002SFP
Serial cable
Length
1.8 m
Blue
Connector
RJ-45 - male
RoHS
Length: 1.8m
Colour: Blue
Stock Status: In stock
