Connect your computer's serial port to the RJ45 console port on your Cisco router. The DB9CONCABL6 6ft Cisco Console Management Cable is designed as a replacement cable for use with several Cisco routers, including the 600, 800, 1600 and 1700 series.
StarTech.com's Cisco Console Management cable is Equivalent to Cisco Part No. CAB-CONSOLE-RJ45 and AIR-CONCAB1200 Console Cable for 1130AG, 1200, 1230AG, and 1240 Platforms.
Reliable connectivity
The serial cable features a male RJ-45 connector and a female DB-9 connector, allowing for seamless integration with network routers and other serial devices. -
Sustainable choice
Compliant with RoHS standards, this cable minimizes environmental impact while providing performance for console management.
- StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F Serial Console Cable (DB9CONCABL6) - serial cable - RJ-45 to DB-9 - 1.8 m
- Serial cable
- Length
- 1.8 m
- Connector
- RJ-45 - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Blue
- Limited lifetime warranty
- Designed For
- P/N: EC1S952, EC2S952, IES101002SFP
- Serial cable
- Length
- 1.8 m
- Blue
- Connector
- RJ-45 - male
- RoHS
- Designed For
