Product
StarTech.com 6 ft Parallel Printer Cable
Quicklinx: 76SWWS00 Mfr#: PB6_
Length: 1.8m
More than 50 in stock
£4.55 ex VAT
£5.46 inc VAT
Only best-quality components are used when StarTech.com's expert manufacturing team creates its cabling and this cable is not different. Connect a data switch or PC to a parallel printer with the StarTech.com PB10, a standard printer cable. This product helps StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
StarTech.com 6 ft DB25 to Centronics 36 Parallel Printer Cable - M/M - printer cable - 1.8 m
Printer cable
Length
1.8 m
Connector
DB-25 - male
Connector (Second End)
36 PIN Centronics - male
P/N: PCI1P2, EC1PECP, PM1115P, PCI1P, PCI2S1PGB, PCI1PECPGB, 10PKPCI1PECP, PCI1P_LP, PCI2PECP, PCI2S1P, PCI1PECP
Printer cable
Length
1.8 m
Connector
25 pin D-Sub (DB-25) - male
StarTech.com 1 Port 10/100 Mbps Parallel Network Print Server, 1 port ExpressCard EPP/ECP Parallel Card, 1 Port Low Profile PCI Parallel Adapter Card, 1 Port PCI Parallel Adapter Card, 2 Port PCI Parallel Adapter Card - EPP/ECP, 2S1P PCI Serial Parallel Combo Card with 16550 UART, PCI1PECP, Value1 Port PCI Parallel Adapter Card
Length: 1.8m
Price Range Ex VAT: 0 - 50
