StarTech.com 6 ft Mini USB Cable - A to Right Angle Mini B
Quicklinx: 7P40WS00 Mfr#: USB2HABM6RA
Connect your Mini USB devices, with the cable out of the way. The USB2HABM6RA 6ft USB to Right Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The right-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a 6ft USB A to Left Angle Mini B Cable (USB2HABM6LA), which provides the same convenience as this right-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
StarTech.com 6 ft. (1.8 m) Right Angle USB to Mini USB Cable - USB 2.0 A to Right Angle Mini B - Black - Mini USB Cable (USB2HABM6RA) - USB cable - USB to mini-USB Type B - 1.8 m
USB cable
90° connector, right-angled connector
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
P/N: SV565HDIP
USB cable
American Wire Gauge (AWG)
28
Length
1.8 m
Connector
USB / USB 2.0, RoHS
P/N: SV565HDIP
7P40 StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
7P40 StarTech.com 1 ft Panel Mount USB Cable B to B - F/M In Stock £5.68
7P40 StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £85.03
7P40 StarTech.com 6in Mini USB 2.0 Cable - A to Mini B In Stock £4.07
7P40 StarTech.com 3 ft Panel Mount USB Cable B to B - F/M In Stock £5.69
