StarTech.com 6 ft Mini DisplayPort to VGA Cable - M/M
Quicklinx: 76MRWS00 Mfr#: MDP2VGAMM6
Type: DisplayPort
Length: 1.83m
£10.80 ex VAT
£12.96 inc VAT
Connect your VGA monitor to a mini DisplayPort-equipped computer using a single cable. The MDP2VGAMM6 6-foot mini DisplayPort to VGA cable is a cost-effective mini DisplayPort to VGA link that lets you connect a VGA monitor to a PC or Mac with a mini DisplayPort output - saving the expense of upgrading the monitor for compatibility.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. This all-in-one, easy to use Mini DisplayPort/VGA cable requires no additional converters or adapters, and no driver or software installation.
StarTech.com 6 ft. (1.8 m) Mini Displayport to VGA Cable - 1920x1200 / 1080p - Thunderbolt Compatible - VGA Monitor Cable (MDP2VGAMM6) - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
Active cable (signal regeneration), Thunderbolt port compatible
1 - 1.8 cm
FCC, RoHS, WEEE
90 g
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
20 - 80%
76MR StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
76MR StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
76MR StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.72
76MR StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White In Stock £6.11
76MR StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £15.08
Type: DisplayPort
Length: 1.83m
