StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M
Quicklinx: 76MVWS00 Mfr#: MDP2DVIMM6
Type: DVI
Length: 1.8m
More than 50 in stock
£23.32 ex VAT
£27.98 inc VAT
Connect your DVI monitor to a Mini DisplayPort-equipped computer using a single cable.
The MDP2DVIMM6 6-foot Mini DisplayPort to DVI Cable is a cost-effective Mini DisplayPort to DVI link that lets you connect a DVI monitor to a PC or Mac with a Mini DisplayPort output - saving the expense of upgrading the monitor for compatibility. This all-in-one, easy to use Mini DisplayPort/DVI cable requires no additional converters or adapters, and no driver or software installation.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
MDP2DVIMM6 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M - MDP to DVI Cable - MiniDP to DVI - Mini DP to DVI Converter (MDP2DVIMM6) - DisplayPort cable - 1.8 m
DisplayPort cable
Length
1.8 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
DisplayPort cable
Length
1.8 m
Connector
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
76MV StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £10.55
76MV StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.32
76MV StarTech.com Mini DisplayPort to DVI Active Adapter In Stock £14.22
76MV StarTech.com Mini DisplayPort to DVI Video Adapter Converter - White In Stock £10.65
76MV StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £10.55
76MV StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £12.97
76MV StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £19.58
Type: DVI
Length: 1.8m
Price Range Ex VAT: 0 - 50
