Your basket is empty
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black
Quicklinx: 8VVGWS00 Mfr#: MDP2DVIMM6B
Length: 1.82m
27 in stock
£14.72 ex VAT
£17.66 inc VAT
Standard delivery Delivered within 3-5 working days
Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a 6 foot distance - Black. The MDP2DVIMM6BMini DisplayPortto DVI Adapter Cable lets you directly connect your Mini DPvideo source (Desktop PC, Laptop, Ultrabook, etc.) to a DVI monitor or projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cableis 6 feet (1.8 m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM6B is a passive adapter that requires a dual-mode DisplayPortport (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 6ft Mini DisplayPort to DVI Adapter Cable Mini DP to DVI Black - DisplayPort cable - 1.82 m
DisplayPort cable
Length
1.82 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
2 years warranty
DisplayPort cable
Length
1.82 m
Connector
24+1 pin digital DVI - male
FCC, RoHS
2 years warranty
Length: 1.82m
Price Range Ex VAT: 0 - 50
