StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black
Quicklinx: 8VVGWS00 Mfr#: MDP2DVIMM6B
Length: 1.82m
Hurry, only 3 left in stock!
£14.55 ex VAT
£17.46 inc VAT
Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a 6 foot distance - Black. The MDP2DVIMM6BMini DisplayPortto DVI Adapter Cable lets you directly connect your Mini DPvideo source (Desktop PC, Laptop, Ultrabook, etc.) to a DVI monitor or projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cableis 6 feet (1.8 m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM6B is a passive adapter that requires a dual-mode DisplayPortport (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
  • Reliable Connection
    Equipped with a male Mini DisplayPort on one end and a 24+1 pin digital DVI connector on the other, this cable provides a stable connection for transmitting your digital video.
  • Multi-Device Compatibility
    This cable connects seamlessly with both Windows PCs and Mac computers, making it suitable for mixed environment setups.
StarTech.com 6ft Mini DisplayPort to DVI Cable - M/M - mDP Cable for Your DVI Monitor / TV - Windows & Mac Compatible (MDP2DVIMM6B) - DisplayPort cable - 1.82 m
DisplayPort cable
Length
1.82 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
DisplayPort cable
Length
1.82 m
Connector
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
8VVG StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.55
8VVG StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.23
8VVG StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £9.73
8VVG StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £11.84
8VVG StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £14.55
8VVG StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £18.47
Length: 1.82m
