Connect a DVI display to a Mini DisplayPort-equipped PC or MAC over a 6 foot distance - Black. The MDP2DVIMM6BMini DisplayPortto DVI Adapter Cable lets you directly connect your Mini DPvideo source (Desktop PC, Laptop, Ultrabook, etc.) to a DVI monitor or projector, eliminating the expense of having to upgrade to a Mini DisplayPort-capable monitor.
The adapter cableis 6 feet (1.8 m) in length, and features male-to-male connectors, allowing you to connect your Mini DisplayPort source directly to a DVI display with no additional cabling required.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
MDP2DVIMM6B is a passive adapter that requires a dual-mode DisplayPortport (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Reliable Connection
Equipped with a male Mini DisplayPort on one end and a 24+1 pin digital DVI connector on the other, this cable provides a stable connection for transmitting your digital video. -
Multi-Device Compatibility
This cable connects seamlessly with both Windows PCs and Mac computers, making it suitable for mixed environment setups.
- StarTech.com 6ft Mini DisplayPort to DVI Cable - M/M - mDP Cable for Your DVI Monitor / TV - Windows & Mac Compatible (MDP2DVIMM6B) - DisplayPort cable - 1.82 m
- DisplayPort cable
- Length
- 1.82 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-D - male
- FCC, RoHS
- Black
- 3-year warranty
- DisplayPort cable
- Length
- 1.82 m
- Black
- Connector
- 24+1 pin digital DVI - male
- FCC, RoHS
- 3-year warranty
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £9.72 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £23.80 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £9.88 |
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £12.06 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £13.79 |
