Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM6 6ft Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
High-quality connectivity
This 6 ft Mini DisplayPort to DisplayPort 1.2 cable offers a direct connection to ensure reliable signal transmission between your devices. With its latching DisplayPort connector, it provides a secure connection that won't accidentally disconnect, ensuring uninterrupted viewing. -
Versatile compatibility
Designed to be compatible with both Mac and PC, this adapter cable offers a versatile solution for connecting a Mini DisplayPort source to a DisplayPort display. Whether for work presentations or home entertainment, this cable supports a wide range of applications. -
Superior video quality
Supporting resolutions up to 4K x 2K UHD, the cable delivers crystal-clear video quality. The nickel-plated connectors not only ensure a solid connection but also maintain the integrity of the signal to provide a high-quality visual experience.
- StarTech.com 6ft (2m) Mini DisplayPort to DisplayPort 1.2 Cable, 4K x 2K UHD Mini DisplayPort to DisplayPort Adapter Cable, Mini DP to DP Cable for Monitor, mDP to DP Converter Cord - Latching DP Connector - DisplayPort cable - 1.8 m
- DisplayPort cable
- Latched
- Length
- 1.8 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DisplayPort - male
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: BOX4HDECP, CDP2DP, CDP2DP14B, CDP2DPW, CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, DP2MDPMF3, DP2MDPMF6IN, DPBOOST, HD2DP, MDPEXT3, SP123DP, SV231DPU, SV231DPUA, SV431DPDDUA2, SV431DPUA2, TB2DOCK4K2DP
- DisplayPort cable
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Nickel
- Latched
- Length
- 1.8 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS
- Designed For
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.12 |
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.14 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £9.52 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £15.74 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.43 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.75 |
StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £15.35 |
StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £14.48 |
StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £5.85 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £21.60 |
StarTech.com USB 3.0 to 4K DisplayPort External Multi Monitor Video Graphics Adapter | In Stock | £74.49 |
