StarTech.com 6 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k
Quicklinx: 7NZPWS00 Mfr#: MDPEXT6
Length: 1.8m
Select:
£23.40 ex VAT
£28.08 inc VAT
Create a high-resolution 4k x 2k extension with HBR2 support between your Mini DisplayPort -equipped devices. This Mini DisplayPort 1.2 cable lets you extend the connection distance between your Mini DP devices by up to 6 feet.
The cable delivers the ideal solution for better placement of peripheral devices and can be used to connect your Microsoft Surface Pro 4, Surface Book, MacBook, MacBook Pro, MacBook Air, and other mDP enabled devices to Apple's LED Cinema Display or other Mini DisplayPort monitor.
Simply connect your tablet or laptop to the extension cable using a standard MDISPLPORT6" text="Mini DisplayPort Cable and connect the extension cable to your Mini DP monitor.
The cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Please note: Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DisplayPort Cables can be connected to the Thunderbolt ports, enabling you to connect your Mini DP compatible displays.
StarTech.com 6 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k with HBR2 support - Mini DP Extension Cable 6 feet (MDPEXT6) - DisplayPort extension cable - 1.8 m
Double shielded
Latched, molded
Length
1.8 m
Connector
Mini DisplayPort - female
Connector (Second End)
Mini DisplayPort - male
RoHS
Double shielded
Shielding Material
American Wire Gauge (AWG)
32
Latched, molded
Length
1.8 m
Connector
RoHS
7NZP StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.27
7NZP StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £10.43
7NZP StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £14.70
7NZP StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £11.07
7NZP StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £16.12
Length: 1.8m
