StarTech.com 6 ft Micro USB Cable A to Right Angle Micro B
Quicklinx: 98F0WS00 Mfr#: UUSBHAUB6RA
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB6RA 6-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The right-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a 6ft USB A to Left Angle Micro B Cable (UUSBHAUB6LA), which provides the same convenience as this right-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
StarTech.com 6 ft. (1.8 m) Right Angle Micro USB Cable - USB 2.0 A to Right Angle Micro B - Black - Micro USB Cable (UUSBHAUB6RA) - USB cable - USB to Micro-USB Type B - 1.8 m
USB cable
90° connector
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
P/N: ST4200MINI2, USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
90° connector
Length
1.8 m
Connector
RoHS
98F0 StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.99
98F0 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £103.00
98F0 StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.96
98F0 StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £24.95
98F0 StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
98F0 StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £15.09
98F0 StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
98F0 StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £110.30
98F0 StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £14.91
98F0 StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £128.27
98F0 StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £64.21
98F0 StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £44.32
98F0 StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £56.18
98F0 StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £12.51
98F0 StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £39.49
98F0 StarTech.com 0.5m Angled Micro USB Cable In Stock £4.71
98F0 StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £30.57
