StarTech.com 6 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable HDMI to HDMI M/M
Quicklinx: 7NYWWS00 Mfr#: HDMIMM6HS
Length: 1.8m
43 in stock
£7.82 ex VAT
£9.38 inc VAT
Create Ultra HD connections between your HDMI -enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM6HS 6-foot High Speed HDMI Cable with Ethernet supports the advanced capabilities of the High-Definition Multimedia Interface, including Ethernet data inter-connectivity with compatible HDMI-enabled products, and is fully backward compatible with older HDMI-capable devices.
The cable features gold-plated HDMI (male) connectors which help to ensure a high quality digital connection capable of transmitting high-definition video and multi-channel audio between devices such as Blu-Ray Disc players, HDTVs, DVD Players, DVRs, stereo receivers and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
All StarTech.com High Speed HDMI Cables are expertly designed and constructed of top quality materials to deliver dependable high-definition performance.
StarTech.com 6 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - 1080p Audio/Video, Gold-Plated (HDMIMM6HS) - HDMI with Ethernet cable - 1.8 m
Cable
Double shielded
American Wire Gauge (AWG)
28
Length
1.8 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC)
P/N: LENYMCHDVUGK, SV431DHD4KU, SV431HDU3A2
Cable Type
Double shielded
28
Jacket Material
PVC
Shielding Material
Length
1.8 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
7NYW StarTech.com 10 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £8.85
7NYW StarTech.com 15 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £16.58
7NYW StarTech.com 20 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £31.80
7NYW StarTech.com 6 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £6.94
7NYW StarTech.com 6 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable HDMI to HDMI M/M In Stock £7.82
Length: 1.8m
Price Range Ex VAT: 0 - 50
