StarTech.com 6 ft HDMI to DVI-D Cable - M/M
Quicklinx: 4JDRWS00 Mfr#: HDMIDVIMM6
Select:
  • 2m
More than 50 In Stock
£7.92 ex VAT
£9.50 inc VAT
Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM6 6-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
  • High compatibility
    This 6 ft HDMI to DVI cable offers a practical solution for connecting HDMI-capable devices to DVI-D equipment, enabling users to enjoy a reliable connection between their computer and a DVI monitor or projector.
  • Reliable quality
    Crafted with high-quality materials, this video adapter cable ensures optimal performance. The durable design ensures a secure connection and prolonged lifespan, making it a wise investment for digital monitor setups.
  • Effortless installation
    Featuring a Plug-and-Play design, this cable simplifies the setup process, eliminating the need for complicated installation or additional software. Users can easily connect their devices and enjoy high-resolution video in minutes.
StarTech.com 6ft (1.8m) HDMI to DVI Cable, DVI-D to HDMI Display Cable (1920x1200p), Black, 19 Pin HDMI Male to DVI-D Male Cable Adapter, Digital Monitor Cable, M/M, Single Link - DVI to HDMI Cord (HDMIDVIMM6) - adapter cable - 1.83 m
Cable
Adapter cable
Length
1.83 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CDVPD, MDP2HDEC, MSTCDP122HD, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, USB32HD2, USBC2DVCAPRO, UVCHDCAP, VID2HDCON2, VS424HD4K60
Cable Type
Adapter cable
Length
1.83 m
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
Limited warranty - lifetime
P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CDVPD, DKWG30DPHPD, DKWG30DPHPDU, DP2DVI, DP2DVI2, DP2DVIS, DP2HD4KS, DP2HDMI, DP2HDMI2, DP2HDMIADAP, DVI92030202L, DVISPL1DD, HDBOOST, HDMI2HDMI, HDMI2VGA, HDMIPNLFM3, HDVGADP2HD, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, MDP2HD4KS, MDP2HDEC, MDP2HDMI, MDP2HDW, MHD2HDF11, MSTCDP122HD, MSTDP123HD, MSTMDP123HD, MSTP3MDPUGBK, MSTS3MDPUGBK, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121HDFXA, ST121HDWP, ST121SHD30, ST121SHD50, ST121USBHD, ST121UTPHD2, ST121WHD2, ST121WHDS, ST122DVIA, ST122HD4K, ST122HD4KU, ST122HDMI2, ST122HDMILE, ST124DVIA, ST124HD4K, ST124HDMI2, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, ST424HDBT, STDHVHDBT, STHDBTRX, SV831DVIU, TB32HD2, USB2DVIE3, USB2DVIPRO2, USB2HDCAPS, USB32DVCAPRO, USB32DVIEH, USB32DVIPRO, USB32HD2, USB32HD4K, USB32HDDVII, USB32HDEH, USB32HDES, USB32HDPRO, USB3SMDOCKHV, USBC2DVCAPRO, UVCHDCAP, VGA2HD2, VID2HDCON, VID2HDCON2, VS221HD2VGA, VS221HD4K, VS221HD4KA, VS221HDQ, VS221VGA2HD, VS222HD4K, VS222HDQ, VS420RDVIA, VS421HD4K, VS421HD4KA, VS421HDPIP, VS424HD4K60, VS424HDPIP, VS440HDMI, VS721MULTI, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
