This 6ft DVI to VGA Monitor Cable features a DVI (analog) male connector and a VGA (High Density D-Sub) male connector, providing a cost-effective way to connect an analog or dual mode Flat Panel Display to a PC or Mac computer with a DVI Analog Video Card.
The 6ft DVI to VGA Monitor cable is expertly designed and constructed of only high quality materials.
- StarTech.com 6 ft DVI to Coax High Resolution VGA Monitor Cable - video cable - 1.8 m
- Video cable
- Length
- 1.8 m
- Connector
- HD-15 - male
- Connector (Second End)
- DVI-A - male
- FCC
- Black
- Limited lifetime warranty
- Designed For
- P/N: USB2VGADVI
- Video cable
- Length
- 1.8 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 12+5 pin analogue DVI - male
- FCC
- Designed For
- StarTech.com USB VGA and DVI Dual Port External Video Adapter
