StarTech.com 6 ft DVI-I Dual Link Digital Analog Monitor Extension Cable M/F
Quicklinx: 76M1WS00 Mfr#: DVIIDMF6
Extend your DVI-I (dual link) connection by 6ft. The DVIIDMF6 DVI-I Dual-Link Digital Analog Monitor Extension Cable allows you to extend the connection distance between your DVI-I devices by up to 6-feet.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
StarTech.com DVI-I Extension Cable - 6 ft - Dual Link - Digital and Analog - Male to Female Cable - Computer Monitor Cable - DVI Cord (DVIIDMF6) - DVI extension cable - 1.83 m
DVI extension cable - dual link
Length
1.83 m
Connector
DVI-I - male
Connector (Second End)
DVI-I - female
P/N: AGPVID5500A, ST121UTPDVGB
DVI extension cable
TMDS Links
Dual link
Length
1.83 m
Connector
24+5 pin combined DVI - male
24+5 pin combined DVI - female
