StarTech.com 6 ft DVI-D Single Link Monitor Extension Cable - M/F
Quicklinx: 3ZL4WS00 Mfr#: DVIDSMF6
Type: DVI
Length: 1.8m
Select:
Hurry, only 2 left in stock!
£9.42 ex VAT
£11.30 inc VAT
Extend your DVI-D (single link) connection by 6ft. The DVIDSMF6 DVI-D Single-Link Monitor Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 6-feet.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
StarTech.com DVI Extension Cable - 6 ft - Single Link - Male to Female Cable - 1920x1200 - DVI-D Cable - Computer Monitor Cable - DVI Cord (DVIDSMF6) - DVI extension cable - 1.8 m
DVI extension cable - single link
Length
1.8 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
Plug and Play
P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
DVI extension cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Plated Connector
Nickel
Length
1.8 m
Connector
18+1 pin digital DVI (Single-Link) - male
18+1 pin digital DVI (Single-Link) - female
Plug and Play
Type: DVI
Length: 1.8m
Price Range Ex VAT: 0 - 50
