Extend your DVI-D (single link) connection by 6ft. The DVIDSMF6 DVI-D Single-Link Monitor Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 6-feet.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
- StarTech.com DVI Extension Cable - 6 ft - Single Link - Male to Female Cable - 1920x1200 - DVI-D Cable - Computer Monitor Cable - DVI Cord (DVIDSMF6) - DVI extension cable - 1.8 m
- DVI extension cable - single link
- Length
- 1.8 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - female
- Plug and Play
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Single link
- Plated Connector
- Nickel
- Length
- 1.8 m
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- 18+1 pin digital DVI (Single-Link) - female
- Plug and Play
- Designed For
