Product
StarTech.com 6 ft DVI-D Dual Link Cable - M/M
Customer rating: 3.0* (Write a review)
Quicklinx: 3ZL6WS00 Mfr#: DVIDDMM6
Type: DVI
Length: 1.8m
More than 50 in stock
£6.71 ex VAT
£8.05 inc VAT
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM6 6ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 6 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com 6 ft DVI-D Dual Link Cable - M/M - DVI cable - 1.8 m
DVI cable - dual link
Length
1.8 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: RKCONS2001GB, RACKCONS2001, DP2DVID, SV431DVIDGB, DVI2HDMI, HDMI2DVI, SV431DVIDDU, SV431DDUSB, SV231DDUSB, VID2DVIDTVGB, VGA2DVIIGB, VGA2DVII, VID2DVIDTV, SV421DVIDD, SV221DVIDD, SV421DVI, SV221DVI
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
1.8 m
Connector
24+1 pin digital DVI - male
StarTech.com 2 Port DVI PS/2 KVM Switch, 4 Port DVI Dual Monitor KVM Switch with PS/2, Composite and S-Video to DVI-D Video Converter with Scaler, DisplayPort to DVI Dual Link Active Converter – USB Powered, DVI and Digital Audio to HDMI Converter, HDMI to DVI-D Video Converter with Audio, High Res RackMount LCD Console for 19" Rack, VGA to DVI-I Video Converter with Scaler , StarTech.com Converge A/V HDMI to DVI-D with SPDIF Audio Converter , StarTech.com StarView DVI KVM Switch SV421DVI
3ZL6 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.71
3ZL6 StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £13.17
3ZL6 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
Customer reviews
Write a review for the StarTech.com 6 ft DVI-D Dual Link Cable - M/M here!
Needed DVI-D connections only
Reviewed by MD. Review Posted 30/09/2008
Worked fine for me. Good signal even via KVM unit.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Not good
Reviewed by Calum. Review Posted 11/07/2008
This cable did work for me, but yesterday it pulled out one of the pins which are used to hold it in place on my graphics card, the bits it screws into (not sure what they're called).
This was after it decided to stop working too.
I'm not impressed with this cable, it's completely died after about a month with me plugging/unplugging maybe 4 times in total, and it nearly took my £140 graphics card with it. It has damaged my card and I will be contacting Startech about this.
I would not advise getting this cable, get a better brand.
  • Overall 1*
  • Ease of use 5*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: DVI
Length: 1.8m
Price Range Ex VAT: 0 - 50
