Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM6 6ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 6 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com 6ft Dual Link DVI Cable – M/M – DVI-D Video Cable for Your Computer Monitor / Display – DVI to DVI Cord (DVIDDMM6) - DVI cable - 1.8 m
DVI cable - dual link
Length
1.8 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DK30BACDD, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, HD2DPVGADVI, MDP2DVID2, MST30C2HHPD, MST30C2HHPDU, RKCOND17HD, SV431DL2DU3A
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
1.8 m
Connector
24+1 pin digital DVI - male
P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DK30BACDD, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2DVI, DP2DVI2, DP2DVID2, DP2DVIS, DP2VGDVHD, DVI92030202L, DVIDDMM15, DVIEXTAA6IN, DVISPL1DD, HD2DPVGADVI, HDDVIMF8IN, HDMIDVIMF, MDP2DPDVHD, MDP2DVI, MDP2DVI3, MDP2DVID2, MDP2DVIS, MDP2DVIW, MST30C2HHPD, MST30C2HHPDU, RKCOND17HD, SV221DVIDD, SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DVIDDU, SV231DVIUAHR, SV231DVIUDDM, SV231QDVIUA, SV231TDVIUA, SV431DD2DUA, SV431DDUSB, SV431DDVDUA, SV431DL2DU3A, SV431DVIDDU, SV431DVIUAHR, SV431TDVIUA, SV831DVIU, USB2DVIE3, USB2DVIPRO2, USB32DVIEH, USB32DVIPRO, USB32HDDVII, USB3SDOCKDD, USB3SDOCKHDV, VSEDIDDVI
Customer reviews
Write a review for the StarTech.com 6 ft DVI-D Dual Link Cable - M/M here!
Needed DVI-D connections only
Reviewed by MD. Review Posted 30/09/2008
Worked fine for me. Good signal even via KVM unit.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Not good
Reviewed by Calum. Review Posted 11/07/2008
This cable did work for me, but yesterday it pulled out one of the pins which are used to hold it in place on my graphics card, the bits it screws into (not sure what they're called).
This was after it decided to stop working too.
I'm not impressed with this cable, it's completely died after about a month with me plugging/unplugging maybe 4 times in total, and it nearly took my £140 graphics card with it. It has damaged my card and I will be contacting Startech about this.
I would not advise getting this cable, get a better brand.
  • Overall 1*
  • Ease of use 5*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
