StarTech.com 6 ft DP to HDMI cable - 4K
Quicklinx: B90YWS00 Mfr#: DP2HDMM2MB
Hurry, only 1 left in stock!
£15.82 ex VAT
£18.98 inc VAT
Eliminate clutter by connecting your PC directly to an HDMI display. This 6-foot (2M) DisplayPort to HDMI adapter cable lets you connect your DisplayPort equipped Ultrabook, laptop or desktop computer to an HDMI display or projector with no additional adapters or cables required. The passive adapter supports video resolutions up to Ultra HD 4K.
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting DisplayPort to HDMI. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this DP to HDMI adapter connects directly from your DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling.
At 6ft (2m) in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For shorter installations, StarTech.com also offers a 3 ft DP to HDMI cable (DP2HDMM1MB), enabling you to choose the right cable length for your custom installation needs.
  • Astonishing picture quality
  • Hassle-free setup
  • Clutter-free installation
    At 6.5ft (2m) in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For shorter installations, we also offer a 3 ft DP to HDMI cable (DP2HDMM1MB), enabling you to choose the right cable length for your custom installation needs. The DP2HDMM2MB is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com 6.5 ft / 2m DisplayPort to HDMI converter cable - 4K (DP2HDMM2MB) - adapter cable - DisplayPort / HDMI - 2 m
Cable
Adapter cable - DisplayPort / HDMI
Length
2 m
Connector
DisplayPort - male
Connector (Second End)
HDMI - male
DisplayPort 1.2
4K support
3-year warranty
P/N: DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, DK30CHDDPPD, DK30CHDPPDUE
Cable Type
Adapter cable 4K support
Interface Supported
DisplayPort / HDMI
DisplayPort 1.2
Length
2 m
HDCP compliant, DPCP compliant
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - male
FCC, RoHS
Limited warranty - 3 years
B90Y StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
B90Y StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.81
B90Y StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
B90Y StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £9.20
B90Y StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.95
B90Y StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £9.26
B90Y StarTech.com HDMI Coupler / Gender Changer - F/F In Stock £8.59
B90Y StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.80
B90Y StarTech.com 3ft DP to HDMI cable - 4K In Stock £13.67
B90Y StarTech.com 6ft mDP to HDMI cable - 4K In Stock £13.79
B90Y StarTech.com 6 ft DP to HDMI cable - 4K In Stock £15.82
B90Y StarTech.com 3ft mDP to HDMI cable - 4K In Stock £13.12
B90Y StarTech.com DisplayPort to HDMI - 4K In Stock £13.26
B90Y StarTech.com 5m DisplayPort to HDMI Cable - 4K In Stock £20.76
B90Y StarTech.com 3m DisplayPort to HDMI Cable - 4K In Stock £18.39
B90Y StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £21.76
B90Y StarTech.com DisplayPort to HDMI Cable In Stock £41.29
