StarTech.com 6 ft DisplayPort to VGA Cable - M/M
Quicklinx: 76RJWS00 Mfr#: DP2VGAMM6
Connect your VGA monitor to a DisplayPort-equipped computer using a single cable. The DP2VGAMM6 6ft DisplayPort to VGA (M-M) Cable lets you connect a VGA capable display to a DisplayPort video card/source. The cable provides a connection distance of 6 feet and features a male VGA connector and a male DisplayPort connector.
The DisplayPort to VGA adapter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your VGA display, while using a cutting edge DisplayPort video source.
StarTech 6ft DisplayPort to VGA Cable – 1920x1200 - M/M – DP to VGA Adapter Cable for Your Computer Monitor or Display (DP2VGAMM6) - DisplayPort cable - 1.83 m
DisplayPort cable
Cable Length
1.83 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
FCC, RoHS
3-year warranty
DisplayPort cable
Cable Length
1.83 m
Connector
20 pin DisplayPort - male
FCC, RoHS
3-year warranty
76RJ StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.33
76RJ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
76RJ StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £6.89
76RJ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.08
76RJ StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F In Stock £13.14
76RJ StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £17.24
76RJ StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.46
76RJ StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £20.51
76RJ StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £14.91
76RJ StarTech.com DP to VGA Adapter with Audio In Stock £19.56
76RJ StarTech.com DisplayPort to VGA Adapter - 1920x1200 In Stock £63.99
