StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M
Quicklinx: 68KSWS00 Mfr#: DP2DVIMM6
Type: DisplayPort
Length: 1.8m
More than 50 in stock
£27.03 ex VAT
£32.43 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer using a single cable. The DP2DVIMM6 DisplayPort to DVI (M-M) video converter cable lets you connect a DVI capable display to a DisplayPort video card/source using a single cable. The cable provides a connection distance of 6ft and features a male DVI connector and a male DisplayPort connector.
The DisplayPort/DVI video converter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your DVI capable display, while using a cutting edge DisplayPort video source.
DP2DVIMM6 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 6ft / 1.8m DisplayPort to DVI Cable - 1920x1200 - DVI Adapter Cable - Multi Monitor Solution for DP to DVI Setup (DP2DVIMM6) - DisplayPort cable - 1.8 m
DisplayPort cable
Length
1.8 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
P/N: DPPNLFM3, DPPNLFM3PW
DisplayPort cable
Plated Connector
Nickel
Length
1.8 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
68KS StarTech.com DisplayPort DVI Video Adapter Converter In Stock £13.69
68KS StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.42
68KS StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £27.03
68KS StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.18
68KS StarTech.com DisplayPort to DVI Active Adapter In Stock £22.04
68KS StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £95.60
68KS StarTech.com 3ft DP to DVI Converter Cable In Stock £15.43
Type: DisplayPort
Length: 1.8m
Price Range Ex VAT: 0 - 50
