Brand
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M
Quicklinx: 68KSWS00 Mfr#: DP2DVIMM6
Type: DisplayPort
Length: 1.8m
29 in stock
£27.03 ex VAT
£32.43 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer using a single cable. The DP2DVIMM6 DisplayPort to DVI (M-M) video converter cable lets you connect a DVI capable display to a DisplayPort video card/source using a single cable. The cable provides a connection distance of 6ft and features a male DVI connector and a male DisplayPort connector.
The DisplayPort/DVI video converter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your DVI capable display, while using a cutting edge DisplayPort video source.
DP2DVIMM6 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
  • Crystal-Clear Picture Quality
    This DP to DVI cable provides high bandwidth video transmissions, supporting monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p. The adapter cable takes full advantage of your DVI capable display while harnessing the video capabilities built into your DisplayPort connection to deliver every detail in stunning high-definition.
  • Simplified Installation
    At 6 ft. (1.8 m) in length, this DVI adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. As well, the cable is easy to use, and requires no additional software or drivers, supporting a true plug-and-play set up.
  • Works with Your Existing DVI Displays
    This DisplayPort to DVI cable makes your DP computer fully compatible with existing DVI monitors or displays in your home or around the office. You can use the cable to either connect to a DVI display or add an additional monitor to your workstation, helping to boost your productivity. DP2DVIMM6 is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: This is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 6ft / 1.8m DisplayPort to DVI Cable - 1920x1200 - DVI Adapter Cable - Multi Monitor Solution for DP to DVI Setup (DP2DVIMM6) - DisplayPort cable - 1.8 m
DisplayPort cable
Length
1.8 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
P/N: DPPNLFM3, DPPNLFM3PW
DisplayPort cable
Plated Connector
Nickel
Length
1.8 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
68KS StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.69
68KS StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £16.09
68KS StarTech.com DisplayPort DVI Video Adapter Converter In Stock £13.69
68KS StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.42
68KS StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £27.03
68KS StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.18
68KS StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £15.53
68KS StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.28
68KS StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £22.43
68KS StarTech.com DisplayPort to DVI Active Adapter In Stock £22.04
68KS StarTech.com 1 ft DVI-D to DVI-D & HDMI Splitter Cable - M/F In Stock £18.22
68KS StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F In Stock £9.65
68KS StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £8.83
68KS StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £95.60
68KS StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £12.97
68KS StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £19.58
68KS StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £24.42
68KS StarTech.com 3ft DP to DVI Converter Cable In Stock £15.77
Type: DisplayPort
Length: 1.8m
Stock Status: In stock
