Connect your DVI monitor to a DisplayPort-equipped computer using a single cable.
The DP2DVI2MM6 DisplayPort to DVI Cable lets you connect a DVI monitor to a DisplayPort video card/source. Providing a connection distance of 6ft, the adapter cable features a male DVI connector and a male DisplayPort connector, allowing you to make a direct video card-to-display connection, as opposed to having to use a separate DVI cable and DisplayPort adapter, or vice versa.
The cable offers high quality construction and supports high bandwidth video transmissions that help ensure optimal monitor resolutions (up to 1920x1200) or HDTV resolutions up to 1080p.
The DP2DVI2MM6 6-foot adapter cable offers a convenient and cost-effective solution for taking full advantage of the capability of your DVI display, without the expense of upgrading to a DisplayPort monitor.
DP2DVI2MM6 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
High-quality connectivity
The StarTech.com DisplayPort to DVI Cable ensures a seamless connection between your DisplayPort-equipped device and a DVI monitor, providing a hassle-free setup for your workstation or home entertainment system. -
Durable design
Featuring a robust PVC jacket and gold-plated connectors, this 6 ft / 2 m video adapter cable is designed for longevity and superior signal transmission, making it a reliable choice for daily use. -
Universal compatibility
With compliance to FCC, REACH, RoHS, and WEEE standards, this passive DisplayPort monitor cable is universally compatible, ensuring you can connect to any DVI display without worrying about compatibility issues.
- StarTech.com DisplayPort to DVI Cable - 6ft / 2m - 1920 x 1200 - M/M – DP to DVI Adapter Cable – Passive DisplayPort Monitor Cable (DP2DVI2MM6) - video adapter cable - DVI-D to DisplayPort - 1.8 m
- Video adapter cable
- Length
- 1.8 m
- Connector
- 24+1 pin digital DVI - male
- Connector (Second End)
- 20 pin DisplayPort - male
- Black
- 3-year warranty
- Jacket Material
- PVC
- Plated Connector
- Gold
- Length
- 1.8 m
- Black
- 4 cm
- 1.5 cm
- 143 g
- Connector
- FCC, RoHS, WEEE, REACH
- Shipping Weight
- 152 g
- 3-year warranty
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.48 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £21.80 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £22.37 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.22 |
StarTech.com 6 ft DisplayPort to DVI Cable - M/M | In Stock | £5.73 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.13 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £10.06 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £41.39 |
StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £18.76 |
StarTech.com 3ft DP to DVI Converter Cable | In Stock | £14.62 |
