StarTech.com 6 ft DisplayPort to DVI Cable - M/M
Quicklinx: 76LMWS00 Mfr#: DP2DVI2MM6
More than 50 in stock
£15.38 ex VAT
£18.45 inc VAT
Connect your DVI monitor to a DisplayPort-equipped computer using a single cable.
The DP2DVI2MM6 DisplayPort to DVI Cable lets you connect a DVI monitor to a DisplayPort video card/source. Providing a connection distance of 6ft, the adapter cable features a male DVI connector and a male DisplayPort connector, allowing you to make a direct video card-to-display connection, as opposed to having to use a separate DVI cable and DisplayPort adapter, or vice versa.
The cable offers high quality construction and supports high bandwidth video transmissions that help ensure optimal monitor resolutions (up to 1920x1200) or HDTV resolutions up to 1080p.
The DP2DVI2MM6 6-foot adapter cable offers a convenient and cost-effective solution for taking full advantage of the capability of your DVI display, without the expense of upgrading to a DisplayPort monitor.
DP2DVI2MM6 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com DisplayPort to DVI Cable - 6ft / 2m - 1920 x 1200 - M/M – DP to DVI Adapter Cable – Passive DisplayPort Monitor Cable (DP2DVI2MM6) - display cable - 1.8 m
Display cable
Length
1.8 m
Connector
24+1 pin digital DVI - male
Connector (Second End)
20 pin DisplayPort - male
3-year warranty
Display cable
Jacket Material
PVC
Plated Connector
Gold
Length
1.8 m
4 cm
1.5 cm
143 g
Connector
FCC, RoHS, WEEE, REACH
Shipping Weight
152 g
3-year warranty
76LM StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.00
76LM StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £28.51
76LM StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.10
76LM StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £15.38
76LM StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £23.16
76LM StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £27.00
76LM StarTech.com 3ft DP to DVI Converter Cable In Stock £15.28
Price Range Ex VAT: 0 - 50
