StarTech.com 6 ft Coax High Resolution 90 degree Down Angled VGA Monitor Cable - HD15 M/M
Quicklinx: 6LC2WS00 Mfr#: MXT101MMHD6
Select:
  • 2m
This 6ft High Resolution Video VGA Cable (90 degree) is designed to provide the highest video quality possible through a VGA connection and is specifically constructed to accommodate tight installation spaces.
The high quality, shielded coax VGA cable features a 90 degree down-angled plug, which requires only 32.4mm (1.27") of space to make the video connection.
More than suitable for high-res VGA applications (1280x1024 resolution and above), the 90 degree VGA cable eliminates picture "ghosting" and fuzzy images that are common with non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
StarTech.com "6 ft Coax High Resolution 90° Down Angled VGA Monitor Cable - HD15 M/M (MXT101MMHD6)" - VGA cable - 1.8 m
VGA cable
90° connector, ferrite bead
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
P/N: CDP2VGA, CDP2VGAFC, SV221NANOU, SV231UAF, VGAPLATE
VGA cable
American Wire Gauge (AWG)
28
Length
1.8 m
Connector
RoHS
6LC2 StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.33
6LC2 StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.17
6LC2 StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £6.89
