Connect your computer to your Cisco router, server, or network equipment. This 6ft Cisco Console Cable/Rollover cable is a cost-effective replacement cable which enables you to connect your computer to your Cisco router, server, or network equipment. This durable Cisco Console Cable is a direct replacement cable that conforms to the Yost serial device wiring standard.
Expertly designed and constructed of only the highest quality materials, the Cisco Console Rollover cable delivers maximum dependability.
- StarTech.com Cisco Console Rollover Cable - RJ45 Ethernet - Network cable - RJ-45 (M) to RJ-45 (M) - 6 ft - molded, flat - blue - ROLLOVERMM6 - network cable - 1.8 m - blue
- Network cable
- Wires per Cable
- 8 wires
- Molded, flat
- Length
- 1.8 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Network cable
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Molded, flat
- Length
- 1.8 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS
StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F | In Stock | £21.20 |
StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F | In Stock | £5.50 |
StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M | In Stock | £7.22 |
StarTech.com 6 ft. (1.8 m) Cisco USB Console Cable - USB to RJ45 | In Stock | £36.50 |
