StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M
Quicklinx: 7P1MWS00 Mfr#: ROLLOVERMM6
Length: 1.8m
Colour: Blue
£7.11 ex VAT
£8.53 inc VAT
Connect your computer to your Cisco router, server, or network equipment. This 6ft Cisco Console Cable/Rollover cable is a cost-effective replacement cable which enables you to connect your computer to your Cisco router, server, or network equipment. This durable Cisco Console Cable is a direct replacement cable that conforms to the Yost serial device wiring standard.
Expertly designed and constructed of only the highest quality materials, the Cisco Console Rollover cable delivers maximum dependability.
  • Efficient connectivity
    The Cisco Console Rollover Cable ensures a reliable connection between devices with its RJ-45 male to RJ-45 male configuration, designed to connect seamlessly to PCs.
  • Durable design
    Crafted with a flat, PVC jacket and featuring an American Wire Gauge (AWG) of 26, this network cable is built for durability and long-term use, resisting environmental factors that typically degrade cable performance.
  • Compliance and compatibility
    Adhering to RoHS compliant standards, this cable not only meets regulatory requirements but also ensures compatibility with a wide range of devices, thanks to its universal RJ-45 connectors.
StarTech.com Cisco Console Rollover Cable - RJ45 Ethernet - Network cable - RJ-45 (M) to RJ-45 (M) - 6 ft - molded, flat - blue - ROLLOVERMM6 - network cable - 1.8 m - blue
Network cable
Wires per Cable
8 wires
Molded, flat
Length
1.8 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Network cable
Jacket Material
PVC
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded, flat
Length
1.8 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS
7P1M StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F In Stock £20.84
7P1M StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F In Stock £5.52
7P1M StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M In Stock £7.11
7P1M StarTech.com 6 ft. (1.8 m) Cisco USB Console Cable - USB to RJ45 In Stock £29.18
Length: 1.8m
Colour: Blue
