Connect your computer to your Cisco router, server, or network equipment. This 6ft Cisco Console Cable/Rollover cable is a cost-effective replacement cable which enables you to connect your computer to your Cisco router, server, or network equipment. This durable Cisco Console Cable is a direct replacement cable that conforms to the Yost serial device wiring standard.
Expertly designed and constructed of only the highest quality materials, the Cisco Console Rollover cable delivers maximum dependability.
Efficient connectivity
The Cisco Console Rollover Cable ensures a reliable connection between devices with its RJ-45 male to RJ-45 male configuration, designed to connect seamlessly to PCs. -
Durable design
Crafted with a flat, PVC jacket and featuring an American Wire Gauge (AWG) of 26, this network cable is built for durability and long-term use, resisting environmental factors that typically degrade cable performance. -
Compliance and compatibility
Adhering to RoHS compliant standards, this cable not only meets regulatory requirements but also ensures compatibility with a wide range of devices, thanks to its universal RJ-45 connectors.
- StarTech.com Cisco Console Rollover Cable - RJ45 Ethernet - Network cable - RJ-45 (M) to RJ-45 (M) - 6 ft - molded, flat - blue - ROLLOVERMM6 - network cable - 1.8 m - blue
- Network cable
- Wires per Cable
- 8 wires
- Molded, flat
- Length
- 1.8 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Network cable
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Molded, flat
- Length
- 1.8 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS
StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F | In Stock | £21.36 |
StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F | In Stock | £5.58 |
StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M | In Stock | £7.27 |
StarTech.com 6 ft. (1.8 m) Cisco USB Console Cable - USB to RJ45 | In Stock | £29.90 |
