StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F
Quicklinx: 76VFWS00 Mfr#: USBEXTAA6BK
Length: 1.8m
More than 50 in stock
£3.59 ex VAT
£4.30 inc VAT
The USBEXTAA6BK 6-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 6 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F - USB extension cable - USB (M) to USB (F) - USB 2.0 - 6 ft - black - USBEXTAA6BK - USB extension cable - USB to USB - 1.8 m
USB extension cable
Double shielded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: 35FCREADBK3, ICUSB2321F, ICUSB232PRO, ICUSB232V2, LTUB1MBK, MSDREADU2OTG, ST4200MINI2, SV221NANOU, UUSBOTG
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
1.8 m
Connector
USB / USB 2.0, RoHS
76VF StarTech.com 6ft High Speed USB 2.0 Cable In Stock £3.18
76VF StarTech.com 6 ft Mini USB Cable - A to Mini B In Stock £3.18
76VF StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.83
76VF StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.26
76VF StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M In Stock £3.17
76VF StarTech.com 6 ft Transparent USB 2.0 Cable - A to B In Stock £3.64
76VF StarTech.com 3 ft A Right Angle to B Right Angle USB Cable - M/M In Stock £4.13
76VF StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £3.88
76VF StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £3.59
76VF StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £3.08
76VF StarTech.com 3m USB 2.0 A to B Cable - M/M In Stock £3.98
76VF StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £5.28
76VF StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £4.52
76VF StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F In Stock £4.91
Length: 1.8m
Price Range Ex VAT: 0 - 50
