StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F
Quicklinx: 76VFWS00 Mfr#: USBEXTAA6BK
Length: 1.8m
More than 50 In Stock
£4.19 ex VAT
£5.02 inc VAT
The USBEXTAA6BK 6-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 6 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
  • Reliable connectivity
    This USB extension cable utilizes a male to female configuration to effectively extend the reach of your USB connections, ensuring that devices can maintain a strong connection even at a distance.
  • Consistent performance
    With compliance to USB 2.0 standards, this cable enables efficient data transfer speeds, enhancing productivity when connecting various devices.
  • Durable construction
    The double shielded design provides protection against external noise and interference, supporting stable and uninterrupted data transfers.
  • Eco-friendly compliance
    Being RoHS compliant, this cable adheres to strict environmental standards, ensuring that no harmful substances are present, making it a responsible choice for consumers.
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F - USB extension cable - USB (M) to USB (F) - USB 2.0 - 6 ft - black - USBEXTAA6BK - USB extension cable - USB to USB - 1.8 m
USB extension cable
Double shielded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: 35FCREADBK3, ICUSB2321F, ICUSB232PRO, ICUSB232V2, LTUB1MBK, MSDREADU2OTG, ST4200MINI2, SV221NANOU, UUSBOTG
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
1.8 m
Connector
USB / USB 2.0, RoHS
76VF StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £5.29
76VF StarTech.com Mini USB to Micro USB Adapter In Stock £3.67
76VF StarTech.com 6in Mini USB 2.0 Cable - A to Mini B In Stock £4.07
76VF StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
76VF StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
76VF StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
76VF StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.99
76VF StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £4.92
76VF StarTech.com 3m USB 2.0 A to B Cable - M/M In Stock £4.51
76VF StarTech.com 6in Micro USB to Mini USB Adapter Cable M/F In Stock £6.13
76VF StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.23
76VF StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £6.37
76VF StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £5.51
76VF StarTech.com 3ft Right Angle Micro-USB Cable In Stock £5.22
76VF StarTech.com 6ft Right Angle Micro-USB Cable In Stock £6.18
76VF StarTech.com 3ft Micro-USB Charging Cable In Stock £4.63
76VF StarTech.com 6 ft Micro-USB Charging Cable In Stock £7.11
76VF StarTech.com 0.5m Angled Micro USB Cable In Stock £4.71
Length: 1.8m
