StarTech.com's professional line of 2-in-1 USB KVM switch cables are specifically designed to work with your StarView or Server Remote Control KVM switch, integrating the necessary USB and VGA connections into a single cable - reducing tangles while maintaining excellent performance.
This 6ft 2-in-1 USB KVM switch cable features an ultra-thin design and is constructed of only high quality materials. This cable is designed for durability and long-term reliability.
- StarTech.com 6 ft Ultra-Thin USB 2-in-1 KVM Cable - Keyboard / video / mouse / USB cable - USB, HD-15 (VGA) (M) to HD-15 (VGA) (M) - 6 ft - black - SVECONUS6 - keyboard / video / mouse / USB cable - 1.83 m
- Length
- 1.83 m
- Connectors
- 15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
- Connectors (Second End)
- Black
- Limited lifetime warranty
- Designed For
- P/N: CAB831HDU, CABCONS1716I, RACKCONS1908, RACKCONS1916, SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV565DUTPU, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV565UTPUL, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV841HDIE, SV841HDIEGB
- Length
- 1.83 m
- Black
- Connectors
- Designed For
- P/N: CAB1631HD, CAB831HD, CAB831HDU, CABCONS1716I, RACKCONS1908, RACKCONS1916, SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV565DUTPU, SV565UTP, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV565UTPUL, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV831HD, SV841HDIE, SV841HDIEGB
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £6.56 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £431.58 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £351.41 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £490.18 |
StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £136.12 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £260.94 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £295.00 |
