StarTech.com 6 ft. (1.8 m) Cisco USB Console Cable - USB to RJ45
Quicklinx: FBZPWS00 Mfr#: ICUSBROLLOVR
Length: 1.8m
Colour: Black
20 In Stock
£30.38 ex VAT
£36.45 inc VAT
This Cisco USB console cable offers a reliable connection from your desktop or laptop to networking equipment that features a console port.
Create a direct connection from the USB 2.0 port on your computer or laptop to the RJ45 console port on your router, server, firewall or switch. This Cisco rollover cable is compatible with most routers, including Cisco, Juniper, Ubiquiti or TP-Link, providing an easy connection for programming your networking equipment from your Windows, Mac or Linux computer.
Expertly designed and constructed with only the highest quality materials, this USB to Ethernet cable provides maximum dependability, supporting data transfer rates up to 460Kbps. It also provides a reliable and hassle-free connection without the need for additional adapters or external power.
  • Compatible USB Connection
  • High-Quality Design
    Expertly designed and constructed with only the highest quality materials, this USB to Ethernet cable provides maximum dependability, supporting data transfer rates up to 460Kbps. It also provides a reliable and hassle-free connection without the need for additional adapters or external power. ICUSBROLLOVR is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 6 ft (1.8 m) Cisco USB Console Cable - USB to RJ45 Rollover Cable - 460Kbps - Windows, Mac and Linux Compatible - M/M (ICUSBROLLOVR) - serial cable - 1.8 m - black
Serial cable - USB / USB 2.0
Shielding Material
PVC
Plastic housing
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Shielding Material
PVC
Plated Connector
Nickel
Plastic housing
Length
1.8 m
1.09 cm
45 g
Connector
RJ-45 - male
RoHS
Shipping Weight
120 g
70 °C
FBZP StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M In Stock £7.27
Length: 1.8m
Colour: Black
