The StarTech.com 6.6 ft (2 m) USB to Serial Adapter Cable is a high-quality solution for connecting serial devices to a USB port. With its COM retention feature, it maintains device names and settings even after disconnecting, making it perfect for setups that require consistent device naming. The cable is equipped with the FTDI FT232R chipset, ensuring reliable data transmission and device communication. Its rugged design, combined with EMI/RFI and electrostatic discharge (ESD) protection, makes it durable and safe for use in various environments. The gold-plated connectors not only enhance the connection quality but also resist corrosion, extending the life of the cable. Additionally, the LED status indicator provides a quick visual cue to monitor the connection status, simplifying troubleshooting. Whether for industrial applications, office use, or any setup requiring serial communication, this adapter cable offers a dependable and efficient solution.
Enhanced durability
The rugged design paired with a thermoplastic elastomer (TPE) jacket material ensures the 6.6 ft USB to Serial Adapter Cable withstands physical stress, making it ideal for demanding environments. -
Reliable connectivity
Featuring a gold-plated connector and a chipset FTDI FT232R, this cable provides a stable connection between devices, minimizing disruptions and ensuring consistent data transmission. -
Advanced protection
With built-in EMI/RFI protection, electrostatic discharge (ESD) protection, and shielded technology, the cable safeguards against external noise and potential damage from static electricity, enhancing device longevity. -
Seamless integration
COM retention allows for easy reconnection and maintenance of device names and settings across reboots, simplifying the setup process for serial devices. -
Visual monitoring
An LED status indicator offers immediate visual feedback on the operational status of the connection, aiding in troubleshooting and ensuring reliable serial communication.
- StarTech.com 6.6ft (2m) USB to Serial Adapter Cable, COM Retention, RS232 - USB / serial cable - USB to DB-9 - 2 m
- Technology
- Shielded
- Molded, rugged, EMI/RFI protection, electrostatic discharge (ESD) protection, LED status indicator, Chipset FTDI FT232R, bus powered, COM retention
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male - screwable
- USB 2.0 / USB 1.1
- Black
- 2-year warranty
- Technology
- Shielded
- Shielding Material
- Copper
- Jacket Material
- Thermoplastic elastomer (TPE)
- Plated Connector
- Gold
- Length
- 2 m
- Black
- 26 g
- Connector
- Included Accessories
- Db9 connector nuts
- USB 2.0 / USB 1.1, RoHS, WEEE, RS-232
- Shipping Weight
- 95 g
- 2-year warranty
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.13 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.14 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.35 |
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.16 |
