StarTech.com 6.6ft/2m USB to Serial Adapter
Quicklinx: J1JQWS00 Mfr#: 1P6FFC-USB-SERIAL
24 In Stock
£27.95 ex VAT
£33.54 inc VAT
The StarTech.com 6.6 ft (2 m) USB to Serial Adapter Cable is a high-quality solution for connecting serial devices to a USB port. With its COM retention feature, it maintains device names and settings even after disconnecting, making it perfect for setups that require consistent device naming. The cable is equipped with the FTDI FT232R chipset, ensuring reliable data transmission and device communication. Its rugged design, combined with EMI/RFI and electrostatic discharge (ESD) protection, makes it durable and safe for use in various environments. The gold-plated connectors not only enhance the connection quality but also resist corrosion, extending the life of the cable. Additionally, the LED status indicator provides a quick visual cue to monitor the connection status, simplifying troubleshooting. Whether for industrial applications, office use, or any setup requiring serial communication, this adapter cable offers a dependable and efficient solution.
  • Enhanced durability
    The rugged design paired with a thermoplastic elastomer (TPE) jacket material ensures the 6.6 ft USB to Serial Adapter Cable withstands physical stress, making it ideal for demanding environments.
  • Reliable connectivity
    Featuring a gold-plated connector and a chipset FTDI FT232R, this cable provides a stable connection between devices, minimizing disruptions and ensuring consistent data transmission.
  • Advanced protection
    With built-in EMI/RFI protection, electrostatic discharge (ESD) protection, and shielded technology, the cable safeguards against external noise and potential damage from static electricity, enhancing device longevity.
  • Seamless integration
    COM retention allows for easy reconnection and maintenance of device names and settings across reboots, simplifying the setup process for serial devices.
  • Visual monitoring
    An LED status indicator offers immediate visual feedback on the operational status of the connection, aiding in troubleshooting and ensuring reliable serial communication.
StarTech.com 6.6ft (2m) USB to Serial Adapter Cable, COM Retention, RS232 - USB / serial cable - USB to DB-9 - 2 m
USB / serial cable
Shielded
Molded, rugged, EMI/RFI protection, electrostatic discharge (ESD) protection, LED status indicator, Chipset FTDI FT232R, bus powered, COM retention
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
9 pin D-Sub (DB-9) - male - screwable
USB 2.0 / USB 1.1
USB / serial cable
Shielded
Shielding Material
Copper
Jacket Material
Thermoplastic elastomer (TPE)
Plated Connector
Gold
Length
2 m
26 g
Connector
Db9 connector nuts
USB 2.0 / USB 1.1, RoHS, WEEE, RS-232
Shipping Weight
95 g
J1JQ StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
J1JQ StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.02
J1JQ StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.35
J1JQ StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.16
