StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable
Quicklinx: FM8KWS00 Mfr#: CDP2DP142MBD
Length: 2m
10 In Stock
£21.99 ex VAT
£26.38 inc VAT
USB Type-C Adapter Cable , 8K 30Hz , Thunderbolt 3 , HBR3. This USB-C to DisplayPort 1.4 cable lets you connect your USB Type-C (or Thunderbolt 3 ) device to a DisplayPort display, or a DP device to a USB-C display with just one cable.
Unparalleled Performance with Support for 8K 30Hz
Supporting four times the resolution of 4K, this 8K DP 1.4 adapter cable delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
The video cable is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
Easy & Clutter-Free Installation
At 6.6 ft. (2 m) in length, this bidirectional adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, we also offer a 3.3 ft. (1 m) USB-C to DP cable, enabling you to choose the right cable length for your custom installation needs.
Convenient, Bi-Directional Support
Use this USB-C to DisplayPort adapter cable to output 8K video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input. For added convenience, the cable supports both Mac & Windows operating systems.
CDP2DP142MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: Your USB 3.1 Type-C device must support DP Alt Mode to work with this cable.
  • Unparalleled Performance with Support for 8K 60Hz
    Supporting four times the resolution of 4K, this 8K DP 1.4 adapter cable delivers the stunning quality of UHD at resolutions up to 7680×4320; and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. The video cable is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
  • IT Pro Performance
    This adapter features a unique video signal booster which amplifies the signal and ensures reliable performance, even with lower quality cables. The amplifier also increases the max. supported DP cable length compared to other brands.
  • Easy &?Clutter-Free?Installation
    At 6.6 ft. (2 m) in length, this?bidirectional adapter?cable?delivers a direct?connection that eliminates excess adapters and cabling,?ensuring?a tidy, professional installation. For shorter installations, we also offer a 3.3?ft. (1 m) USB-C?to DP?cable, enabling you to choose the right?cable?length for your custom installation needs.
  • Convenient,?Bi-Directional?Support
    Use this?USB-C to DisplayPort?adapter cable?to output?8K video?and audio to a?DP display?from the?USB Type-C?(or Thunderbolt 3) port on your laptop or mobile device. With?bi-directional?capabilities, this?cable?can also connect your?DisplayPort-enabled devices to a?display?featuring USB-C input. For added convenience, the cable supports both Mac & Windows operating systems. CDP2DP142MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support.? Note: • Your?USB 3.1 Type-C?device must support?DP?Alt?Mode?to work with this?cable. • To achieve 8K resolutions, your source and your destination must support DisplayPort 1.4. • This cable is not compatible with the Surface Dock 2.
StarTech.com 6ft/2m USB C to DisplayPort 1.4 Cable 8K 60Hz/4K, Bidirectional DP to USB-C or USB-C to DP Reversible Video Adapter Cable, HBR3/HDR/DSC, USB Type C/Thunderbolt 3 Monitor Cable - 8K USB-C to DP Cable - DisplayPort cable - 24 pin USB-C to DisplayPort - 2 m
DisplayPort cable
Active cable, 8K UHD (7680 x 4320) support, DisplayPort Alternate Mode support, bidirectional, High Bit Rate 3 (HBR3)
Length
2 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
20 pin DisplayPort - male (output)
USB 3.1 / Thunderbolt 3 / DisplayPort 1.4
3-year warranty
DisplayPort cable
Length
2 m
Connector
USB 3.1 / Thunderbolt 3 / DisplayPort 1.4, cUL, FCC, RoHS, WEEE, REACH
3-year warranty
FM8K StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £13.14
FM8K StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £13.66
FM8K StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £15.74
FM8K StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.70
FM8K StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.63
FM8K StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.83
Length: 2m
