StarTech.com 6.6 ft. (2 m) HDMI to Mini DisplayPort Cable - 4K - USB-Powe
Quicklinx: FLW6WS00 Mfr#: HD2MDPMM2M
Active Video Converter USB-Powered Mac & Windows . This 6.6 ft. HDMI to Mini DisplayPort cable (male to male) lets you connect an HDMI video source, such as your laptop, desktop, Blu-ray player or camera, to a Mini DP monitor or display without the need for additional video cables and adapters.
Astonishing Picture Quality
With support for 4K at 30Hz, you get a sharp, crisp picture that's richer and more true-to-life than traditional HD, with far greater detail. The HDMI to Mini DisplayPort adapter cable delivers UHD content to your mDP display and supports 7.1 channel surround audio.
The video converter is also backward compatible with 1440p and 1080p displays, which makes it a great accessory to for your existing setup at home or in the office.
Clutter-Free Installation
At 6.6 ft. (2 m) in length, this HDMI to mDP cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, we also offer a 3.3 ft. (1 m) adapter cable, enabling you to choose the right cable length for your custom installation needs.
Convenient Connectivity
This active HDMI to Mini DP converter offers plug-and-play installation, providing a hassle-free setup with no software or drivers to install. The adapter cable is powered via a USB port, avoiding the need for external power adapters.
HD2MDPMM2M is backed by a StarTech.com 3-year warranty and free lifetime technical support.
  • Astonishing picture quality
    With support for 4K at 30Hz, you get a sharp, crisp picture that's richer and more true-to-life than traditional HD, with far greater detail. The HDMI to Mini DisplayPort adapter cable delivers UHD content to your mDP display and supports 7.1 channel surround audio. The video converter is also backward compatible with 1440p and 1080p displays, which makes it a great accessory to for your existing setup at home or in the office.
  • Clutter-free installation
    This HDMI to mDP cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
  • Convenient connectivity
StarTech.com 6ft (2m) HDMI to Mini DisplayPort Cable 4K 30Hz, Active HDMI to mDP Adapter Converter Cable with Audio, USB Powered, Mac & Windows, HDMI Male to mDP Male Video Adapter Cable - HDMI to mDP Converter (HD2MDPMM2M) - video / audio cable - DisplayPort / HDMI - 2 m
Cable
Video / audio cable - DisplayPort / HDMI
Max Output Resolution
3840 x 2160 - 30 Hz
Length
2 m
Connectors
HDMI - male , USB (power only) - male
Connectors (Second End)
Mini DisplayPort - male
4K support
3-year warranty
Cable Type
Video / audio cable 4K support
Interface Supported
DisplayPort / HDMI
Jacket Material
Plastic
Length
2 m
USB powered, active converter
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Connectors
19 pin HDMI Type A - male , 4 pin USB Type A (power only) - male
Plug and Play, FCC, RoHS, REACH
103 g
Shipping Width
21.8 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
115 g
Limited warranty - 3 years
