Add an extra SATA power outlet to your Power Supply.
The PYO2SATA SATA power splitter cable features a SATA male power connector that connects to a single computer power supply SATA connector, and breaks out into two SATA female power connectors.
The SATA power splitter/Y-cable overcomes the limit of the number of SATA drives that can be installed in the system based on available PSU power connections, and eliminates the cost of having to upgrade the power supply to accommodate an additional SATA drive.
Versatile Power Connection
This power splitter allows for a single male SATA power connector to split into two female connectors, facilitating the connection of additional SATA devices without needing multiple power supplies. -
Environmentally Compliant
Compliant with RoHS standards, this cable offers an eco-friendly choice for powering hardware setups, ensuring safety and sustainability in your technology investments.
- StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F - Power splitter - SATA power (M) to SATA power (F) - 6 in - PYO2SATA - power splitter - SATA power to SATA power - 15.2 cm
- Power splitter
- Length
- 15.2 cm
- Connector
- 15 pin Serial ATA power - male
- Connector (Second End)
- 2 x 15 pin Serial ATA power - female
- Limited lifetime warranty
- Designed For
- P/N: 35BAYUSB3S4, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB2535SATBK, PEXUSB311AC3, S251BU31REM, S32M2NGFFPEX, SAT32MSATPEX, SATBP125VP, SATSASBP425
- Power splitter
- Length
- 15.2 cm
- Connector
- RoHS
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £5.06 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.90 |
StarTech.com 8in 15 pin SATA Power Extension Cable | In Stock | £5.30 |
StarTech.com 12in 15 pin SATA Power Extension Cable | In Stock | £7.56 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.60 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £5.90 |
