StarTech.com 5U Vertical Wall Mount Rack, 19" Wall Mounting Bracket, Open Low Profile
Quicklinx: G6R8WS00 Mfr#: RK519WALLV
Product Type: Rack, Rack
£67.80 ex VAT
£81.36 inc VAT
Mount server, network or telecommunications devices vertically with this 4U wall-mountable rack. The RK519WALLV 5U Wallmount Rack Bracket offers a versatile storage solution, allowing equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with the wall) to save space. Alternatively, the 5U bracket can be installed under a desk for horizontal installation, making it easy to access installed equipment directly from your workspace. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Perfect for SoHo (small office, home office) environments, the wallmount bracket offers space-saving installation for environments lacking the footprint space for a full size server equipment rack.
Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes (used to mount to a wall or the desk underside) are positioned at exactly 16in apart, matching standard construction framework.
Constructed to EIA-310 19in rack standards, the wallmount bracket features a sturdy steel design and is backed by StarTech.com's Lifetime Warranty.
Need additional storage? StarTech.com also offers:
1U 19in Wallmount Bracket
2U 19in Wallmount Bracket
3U 19in Wallmount Bracket
4U 19in Wallmount Bracket.
  • Versatile functionality
    This multi-use low profile vertical rack mount bracket enables servers, networking switches, patch panels or AV equipment to be mounted vertically for easy equipment access where a full rack is not desirable.
  • Sturdy design
    This wall mount patch panel bracket features durable solid steel construction, ensuring equipment is mounted safely out of the way.
StarTech.com 5U Vertical Wall Mount Rack - 19in Low Profile Open Wall Mounting Bracket - Network/Server Room/Data/AV/IT/Patch Panel/Communication/Computer Equipment - w/ Cage Nuts/Screws - rack - 5U - TAA Compliant
Rack
Rack Type
Open frame - 2-post
Placing / Mounting
Wall mountable
Package Content
16 M5 cage nuts, 16 M5 screws, 6 M6 cage nuts
Rack Size
19"
Height (Rack Units)
5U
Product Material
Steel
23.5 cm x 50 cm x 15 cm
1.4 kg
TAA Compliant
Rack
Rack Type
Open frame
Rack Post Qty
2-post
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
5U
23.5 cm
50 cm
15 cm
1.4 kg
56 cm x 17.5 cm x 26 cm / 2.2 kg
Weight Limit
90 kg
Mounting Kit
Included
RoHS, ECA-310-E, EIA-310-E
TAA Compliant
Limited warranty: - lifetime
G6R8 StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.52
G6R8 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
G6R8 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
G6R8 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
G6R8 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
G6R8 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
G6R8 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
G6R8 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
G6R8 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
G6R8 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
G6R8 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
G6R8 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
G6R8 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
G6R8 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
G6R8 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
G6R8 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
G6R8 StarTech.com 4U WM Server Rack with Shelf In Stock £105.68
G6R8 StarTech.com 8U WM Server Rack with Shelf In Stock £140.13
G6R8 StarTech.com 6U Wall Mount Rack Bracket In Stock £67.43
G6R8 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
Product Type: Rack
Product Type: Rack
