Mount server, network or telecommunications devices vertically with this 4U wall-mountable rack. The RK519WALLV 5U Wallmount Rack Bracket offers a versatile storage solution, allowing equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with the wall) to save space. Alternatively, the 5U bracket can be installed under a desk for horizontal installation, making it easy to access installed equipment directly from your workspace. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Perfect for SoHo (small office, home office) environments, the wallmount bracket offers space-saving installation for environments lacking the footprint space for a full size server equipment rack.
Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes (used to mount to a wall or the desk underside) are positioned at exactly 16in apart, matching standard construction framework.
Constructed to EIA-310 19in rack standards, the wallmount bracket features a sturdy steel design and is backed by StarTech.com's Lifetime Warranty.
Need additional storage? StarTech.com also offers:
1U 19in Wallmount Bracket
2U 19in Wallmount Bracket
3U 19in Wallmount Bracket
4U 19in Wallmount Bracket.
Versatile functionality
This multi-use low profile vertical rack mount bracket enables servers, networking switches, patch panels or AV equipment to be mounted vertically for easy equipment access where a full rack is not desirable. -
Sturdy design
This wall mount patch panel bracket features durable solid steel construction, ensuring equipment is mounted safely out of the way.
- StarTech.com 5U Vertical Wall Mount Rack - 19in Low Profile Open Wall Mounting Bracket - Network/Server Room/Data/AV/IT/Patch Panel/Communication/Computer Equipment - w/ Cage Nuts/Screws - rack - 5U - TAA Compliant
- Product Type
- Rack
- Rack Type
- Open frame - 2-post
- Placing / Mounting
- Wall mountable
- Package Content
- 16 M5 cage nuts, 16 M5 screws, 6 M6 cage nuts
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 5U
- Product Material
- Steel
- 23.5 cm x 50 cm x 15 cm
- 1.4 kg
- TAA Compliant
- Limited lifetime warranty
- Product Type
- Rack
- Rack Type
- Open frame
- Rack Post Qty
- 2-post
- Wall mountable
- Product Material
- Steel
- Package Content
- Rack Size
- 19"
- 5U
- 23.5 cm
- 50 cm
- 15 cm
- 1.4 kg
- Shipping Dimensions (WxDxH) / Weight
- 56 cm x 17.5 cm x 26 cm / 2.2 kg
- Black
- Weight Limit
- 90 kg
- Mounting Kit
- Included
- RoHS, ECA-310-E, EIA-310-E
- TAA Compliant
- Limited warranty: - lifetime
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £35.52 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £15.50 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £56.58 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.19 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £30.81 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.25 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.56 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.11 |
Startech.com 100 Pkg M6 Mounting Screws | In Stock | £26.84 |
StarTech.com 8U WM Server Rack with Shelf | In Stock | £140.13 |
StarTech.com 6U Wall Mount Rack Bracket | In Stock | £67.43 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.56 |
