StarTech.com 5m Yellow Cat6 Patch Cable
Quicklinx: CNDFWS00 Mfr#: N6PATC5MYL
Length: 5m
Colour: Yellow
£8.24 ex VAT
£9.88 inc VAT
StarTech.com N6PATC5MYL. Cable length: 5 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 180 g. Package width: 255 mm, Package depth: 330 mm, Package height: 40 mm
  • Durable construction
    The PVC jacket provides protection against environmental factors while maintaining flexibility for easy routing. The stranded design allows for better performance, especially in environments where movement is required.
  • High performance
    With a tested frequency of 500 MHz, this Ethernet cable supports high-speed networking for gaming, streaming, and business applications, ensuring smooth and uninterrupted connectivity.
  • Flexible connectivity
    Each end of the cable is equipped with male RJ-45 connectors that facilitate connections to both devices and wall ports, providing a straightforward solution for networking needs.
StarTech.com 5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC5MYL) - network cable - 5 m - yellow
Network cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Snagless, stranded, PoE ready
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
180 g
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE - up to 500 MHz
CNDF StarTech.com 5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.40
CNDF StarTech.com 5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.25
CNDF StarTech.com 5m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £8.22
CNDF StarTech.com 5m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £7.33
CNDF StarTech.com 5m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £8.25
CNDF StarTech.com 5m Green Cat6 Patch Cable In Stock £7.42
CNDF StarTech.com 5m Purple Cat6 Patch Cable In Stock £7.42
Length: 5m
Colour: Yellow
