The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
- Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
- Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
- Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
- StarTech.com 5m Yellow Cat5e / Cat 5 Snagless Ethernet Patch Cable 5 m - network cable - 5 m - yellow
- Network cable - CAT 5e
- Technology
- Wires per Cable
- 8 wires
- Snagless, stranded, PoE ready
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 5 m
- 180 g
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, WEEE - up to 350 MHz
StarTech.com 5m Blue Cat 5e Patch Cable | In Stock | £3.61 |
StarTech.com 5m Black Cat 5e Patch Cable | In Stock | £3.61 |
StarTech.com 5m Orange Cat5e Patch Cable | In Stock | £3.61 |
StarTech.com 5m Yellow Cat5e Patch Cable | In Stock | £1.70 |
StarTech.com 5m White Cat5e Patch Cable | In Stock | £3.64 |
StarTech.com 5m Red Cat5e Patch Cable | In Stock | £1.70 |
