StarTech.com 5m White Cat5e Patch Cable
Quicklinx: CRFTWS00 Mfr#: 45PAT5MWH
Length: 5m
Colour: White
More than 50 In Stock
£6.67 ex VAT
£8.00 inc VAT
The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
  • Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
  • Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
  • Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
  • Find the length and color you need
    This 5-meter white network cable is perfect for use in network conduits and raceways. The cable is intended for longer distance applications, such as running up a post or throughout the office from a hub to a wall- jack. For easier network installations, our Cat 5e cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
  • Snagless RJ45 clips help protect your network connections
    For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break. The cable also features moulded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
  • 100% copper for outstanding value
    Get the highest value for your cable investment with our Cat5e Ethernet cables, each one manufactured using high-quality copper conductors. They are carefully constructed and tested, to keep Near-End Crosstalk (NEXT) well within acceptable limits.
  • 24-gauge wire for high-performance network connection
    Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet and 4K or 1080p video streaming, using cables that include 24 AWG copper.
  • 50-micron gold connectors provide peak conductivity
    You can rely on our RJ45 connectors to deliver optimum conductivity, while eliminating signal loss due to oxidation or corrosion. The 45PAT5MWH is backed by StarTech.com's lifetime warranty for guaranteed reliability.
StarTech.com 5m White Cat5e / Cat 5 Snagless Ethernet Patch Cable 5 m - network cable - 5 m - white
Network cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Snagless, stranded, PoE ready
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
180 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE - up to 350 MHz
CRFT StarTech.com 5m Blue Cat 5e Patch Cable In Stock £6.67
CRFT StarTech.com 5m Black Cat 5e Patch Cable In Stock £6.67
CRFT StarTech.com 5m Orange Cat5e Patch Cable In Stock £6.67
CRFT StarTech.com 5m Yellow Cat5e Patch Cable In Stock £6.67
CRFT StarTech.com 5m White Cat5e Patch Cable In Stock £6.67
CRFT StarTech.com 5m Red Cat5e Patch Cable In Stock £6.75
Length: 5m
Colour: White
